1 - 20 of 41 Posts
Owner of 20 SSDs
there's all the media talk of "OMG 8 core loses to intel 4 core!"
I think that's not really correct, should it be 4 modules vs 4 cores? But then again they look at the Bulldozer and are like "WOAH 8 cores!"
Owner of 20 SSDs
ah, i was confused, because the benchies shows the SB beating the Bulldozer quite badly... which makes me think, should they improve single-thread performance by running one thread per module?
define "core" please...we say things that have no real meanings, like we call most modern cpu's 64bit, but they aren't really, there plenty of parts that have more bits and less bits than that. they have 64 bit gprs, but 128-bit xmm registers, but the memory registers are 48 bit, and most fpu's are 128 bit...so why do we think of them only as 64 bit cpu's?
so to answer your questions, you'd have to answer what makes a core.
Owner of 20 SSDs
yea that's the problem, it used to be that a "core" means the Intel and older AMD models.
However, the bulldozer changes this quite a bit, so, a single definition of "core" doesn't apply to all chips.
Who cares, it doesn't work how it's suppose to, and that's all that really matters in the end, isn't it?
well it never really has
, they add and remove stuff all the time. amd just did it in a grand swoop.
Originally Posted by Malcolm
CPU-Z shows 8 cores/8 threads, so I would assume it's 8 "real" cores?
It's a moduled design where you have 4 modules in the 8150 which are supposed to be equivilent to 8 cores i.e 2 cores per module, but it's not quite the truth.
Simply put you get 1.5 "Cores per module".
Originally Posted by thrasherht
The key part that makes up a core is the actual processing unit inside the core, so since each module has two FPUs in it, that is 2 cores. So yes, 8 cores.
Actually, no.
It has ONE FPU per module. It has two ALUs and two FMACs per module though.
The fact of not having two FPUs per module is why the per-core IPC is so low when running all the eight threads; and it's also the reason why IPC increases so dramatically when one core per module is disabled.
Owner of 20 SSDs
Discussion Starter · #14 ·
http://techreport.com/articles.x/19514
that article finally explains what's going on...
Intel and older AMD processors do CMP, or traditional "moar cores" whereas Bulldozer fused two cores together and makes them share with each other into a module.
Originally Posted by _s3v3n_
So I guess Newegg is lying.
http://www.newegg.com/Product/Produc...960&Tpk=FX8150
"World's First 8-core Desktop CPU"
By classification it's an 8 core processors, but it's not as clear cut as that.
It has 4 modules and each module can be considered 2 cores. But instead of having 2 cores which have their own resources you have 1 module with 2 "cores" that have to share resources within the module. Which leads to a decrease in performance.
PCPer did a test where they ran a benchmark using 2 "cores". 1st test was ran with two "cores" on the same module and the 2nd test was ran with two "cores" from seperate modules (2 modules, one "cores" each).
The 2nd test was faster because each core had it's own resources and didn't have to share resources.
Owner of 20 SSDs
Discussion Starter · #18 ·
so it's basically physical hyperthreading?
No, hyperthreading is physical hyperthreading. This is sharing an FPU between two cores.
Hyperthreading
Hyper-threading works by duplicating certain sections of the processor-those that store the architectural state-but not duplicating the main execution resources. This allows a hyper-threading processor to appear
AMD took the idea to a new step, but didn't quite hit the note they were going for.
I see this discussion alot, to me a core is something identified via the OS, if Windows sees 8 cores then it has 8 cores irregardless of the shortcomings of shared resources. If I had a nickle for everytime I read someone say "don't compare BD to a 2600 because BD doesnt have 8 cores" I could buy AMD. If AMD does not want to compete with 8 core CPU's, even one's with 4 physical cores and 4 virtual ones, then it shouldnt put "8 core" on their boxes.
1 - 20 of 41 Posts
