1 - 12 of 12 Posts
I am wondering if a Cooler Master eXtreme Power Plus 500 W PSU will power my system? I did not overclock it
Specs are below
Originally Posted by Yugimt;12048368
It should be completely fine. The power supply is pretty decent as shown in this review.
That's actually pretty mediocre. If you actually read the conclusion, ripple was out of spec by full load.
It makes a slightly sub-par 400W.
It will run what you've got, but if you don't own it already, get a different PSU.
Discussion Starter · #8 ·
so is it good enough or what i am just using it for 1 more month
If you already own it, its fine. If you're looking to buy it, buy something better.
Reactions: G-Dragon
Discussion Starter · #11 ·
ty i am planning on getting an Corsair TX750
A solid 400w would work fine for your rig as is, or a 600w for Crossfire
. And the TX series is old and outdated too. Check into the Seasonic lineup (I've actually forgotten the newer one
), and the Antec TruePower New line. The Antec will be cheaper, but its got the same internals as the Seasonic (very very close).
1 - 12 of 12 Posts
