1 - 11 of 11 Posts
I just installed the Big T on the same board and it has plenty of room. Awesome cooler too, you will love it.
Discussion Starter · #6 ·
thanks you all have been alot of help.
i have fianlly chosen all the part for my new computer(parts that are missing, i have already)
what case are you using for your typhoon-do you think a antec sonata 2 would house the big typhoon ok?
this is going to be my new rig:
8I945P-G
prescott 630/640
big typhoon
Corsair 1GB DDR2 Value Select PC4200 Dual Channel Kit (2x512MB)
sapphire 800gto2
antec sonata 2+450watt psu-sp
2 -YS-TECH FD1238 120mm Fan-125cfm-does it matter if it is 38mm thickness or will it fit either way.-if it doesn't ill get this one "YS-TECH FD1225 120mm Fan - 4 Pin"
It should fit, you just won't be able to use the air guide on cases with the side window fan. It's not as big as everyone makes it out to be. I thought I would have trouble fitting it in and I still had room for the side fan.
edit: just looked up your case, and with no side window, you should be more than ok fitting it in there.
1 - 11 of 11 Posts
