Is a Phenom 9600 for $50 worth it?
1602 34
As a combo item I can buy a 9600 for $50 extra, the only other proc I was looking at is the x3 710 so is the 710 worth $60 more?
1 - 20 of 35 Posts
Omg yes get the x3 710, you will thank your self later
Discussion Starter · #8 ·
Originally Posted by rambow70 View Post
duo cores are better for gaming but amd's duo suck because of lack of cache i would stay with intel duo
Well I am selling my sig rig so that is not an option right now
Originally Posted by huntman21014 View Post
No, its the 710, the 720 is $85 more
i read it wrong at first
Originally Posted by Sacre View Post
BE? I don't know much about AMDs, but I know people have pushed the AMD 9600 BE past 3.0 on air. (From posts here)
well if you can get close to that, I believe a quad core @ 3.0 will last you a while
I bought a new motherboard as I am into photo and video editing and my E4300 wasn't cutting it, its a Foxconn 790FX motherboard so it should overclock well
Would have probably been cheaper to just upgrade to a Quad Core 775. =/
well the older 790FXs with the SB600 wont oc that well get a sb750 mobo.
and I would say the 710 is worth $60 more. with a SB750 mobo they unlock to quad cores.
yeah 9600s dont get anywhere near 3ghz
or go AM3?
Discussion Starter · #17 ·
Ehh, I wanted a change as I didn't really like this intel setup, no challenge in OC'ing
EDIT> and it does have the 750SB
or...Get a 720?
1 - 20 of 35 Posts
