1 - 16 of 16 Posts
Is there a significant performance increase with 6gbs? my mobo supports it and I just dropped my backup drive. So I am asking because I am thinking of getting a new drive and making my current drive my backup drive.
No difference in mechanical drives.
Only a difference in SSD's if both the motherboard and the drive support the standard.
At the moment, that's only the C300, of which will increase to ~355 MB/sec in sequential reads over a normal ~265 MB/sec using SATA II.
Thats what I wanted to know but wasnt sure since they sell sata 6 drives now a days
Yeah, it's kind of a marketing gimmick.
You may get 6 Gbps from the SATA controller to the IO board of the HDD, but you're still limited from the mechanical aspect of how fast the drive can pull data off of the platters. This tends to be around ~90-115 MB/sec on more modern drives.
I dont get close the 90 when I xfer data
More like 40mb/s. At least thats what windows reported
From where to where?
If you're transferring files on the same drive, you're going to lose a lot due to the RW head moving around.
IIRC 640 Black should be up there at 80+. My 750 Blacks do something like 85-90 MB/sec each..
Discussion Starter · #8 ·
from my sig drive to a caviar blue 320gb. Both plugged directly to the board.
You're likely limited by the write speed of the 320 in this case.
Before I bought the C300 I had a 320g WD in my rig, transfers over gigabit RAID 5 storage (250 MB/sec reads) to the drive were only ~50 MB/sec or so..
Seriously I don't consider SATA6 any kind of marketing gimmick.
If the consumer doesn't know that drives being SATA 6GB/s doesn't mean they'll achieve those speeds it's a consumer (un)education problem.
Sorry but as usual I consider most consumers uneducated and it's not any else's problem except their own.
How is it not a marketing gimmick on mechanical hard drives?
The drive will NEVER even come close to saturating SATA 3 Gbps speeds, why even go through the effort of putting a SATA 6 Gbps controller on the drive other than the sake of taking advantage of the less-than-informed user base?
Discussion Starter · #12 ·
I second this opinion not only because I didnt know but because most consumers arent educated about every computer part. I mean I have built a few rigs and there is still alot of stuff I dont know. If all consumers were educated this forum wouldnt exist as it does really.
Also, most customers, when seeing larger numbers, expect larger transfer rates (or better performance in general).
But I totally agree, a little bit of google and researching goes a long way for everyone.
Discussion Starter · #14 ·
well when google fails ocn never does. And I did google this couldnt seem to find a difinitive answer.
True dat. OCN for all the win.
Sorry....I saw the same thing with SATAI and II and considered that to be a consumer education problem.
I saw the exact same questions.
The problem seems to be that people don't realize that changing the "speed limit" higher doesn't make their "car" any faster.
I consider that an education problem.
1 - 16 of 16 Posts
