Is anyboady running Windows XP 32bit with more than 4GB memory?
862 8
I'm to run 4GB of Kingston hyper-x with a half GB of video on a SLI system. My board sees all of it but Windows does not. I've tried fixing this with the Microsoft solution (PAE/3GB fix in msconfig) and I disabled the page filing system in Windows, I also tried some BOIS tweeks sugjested in a couple of sites where people were apperently B.S.'n.
If anybody has found a way to make this work I really could use some help.
1 - 9 of 9 Posts
I think your a little confused, are you saying your video cards count as 512MB SYSTEM ram? Because they don't, they have integrated onboard RAM, which does not have anything to do with the ram plugged into your motherboard.
1 - 9 of 9 Posts
