1 - 8 of 8 Posts
PC Evangelist
Anything over 1.3625v is considered over-voltage.
maybe with the core 2 quads.
i7's can tolerate higher voltages.
i would say its okay as long as your cooling is up to it
I say up to 1.50 Vcore and 1.5 Vtt as long as the chip stays fairly cool at idle and normal usage, and doesnt go over 95C in stress tests. Be warned, high Vtt, like ~1.5 can kill your chip much quicker, how long it will last, I don't know.
Originally Posted by joe2004
my idle tem is at 43 43 44 45
load them is 79 81 80 83
with those temps you should be fine.
may i ask. is that with HT off??
1 - 8 of 8 Posts
