1 - 9 of 9 Posts
I just bought a corsair h100i a few days ago and I noticed the pump making a faint grinding sound the sound is only noticeable if I have the radiator fans set to quiet , default and balanced if I have the fan speed higher it blanks out the sound should I be worried ? or do all corsair h100i's make this sound ? I bought my corsair h100i from my local tiger direct I still have the receipt should I return it for another one ?
have you checked if your screws hold it tight? it might be ressonance from loose fitting
I installed every think tight I even use the washes that come with it to mount the radiator . I am not worried about the noise any more it is only noticeable when I have the fans on quiet mode default and balanced mode . as long as it is not the pump making that noise I'm good
might be that fans bearing got dust/dried out, if the unit is new i bet they will rma it easy
I wouldn't need to rma it I got it from my local tiger direct I have a receipt and 30 days to return it I only had it less then a week
then return it, they should switch it for new unit as long as you got all the orginal stuffs
Discussion Starter · #9 ·
yes they will excange it with any thing of equal or lesser value or I can add money and get some thing better if I want to return it for cash there is a 15 persent restocking fee
1 - 9 of 9 Posts
