Is it OK to increase NB voltage???
1691 Views 10 Replies 6 Participants Last post by  Jus'Chillin'
Hey I just hit 3.6 with my E6750.
in order to be stable, I had to increase the NB voltage from auto to 1.4v. CPU voltage is 1.5v in the bios.
I have an Asus P5K-E p35 mobo.
So is this NB voltage OK for long term use???
1 - 11 of 11 Posts
Yes, it's fine. Seen a lot of people running it at 1.7-1.10 and some higher also. So you should be just fine at that NB voltage.
1.4v is perfectly safe for a motherboard with an intel chipset. Dont worry about it.
If the temps get too high you will get unstable. Make sure they are under 75C. Ideally, under 65C would be better.
Don't think your board is flashable to the Rampage Formula being a p35, but the P5E to Rampage thread by ericeod is really worth looking at for ASUS mobo voltages, OCing etc: http://www.overclock.net/intel-mothe...hread-155.html
Ok I got blue screens even with NB at 1.4v and CPU voltage at 1.5v in the BIOS, so I upped the BIOS CPU voltage to 1.5125v. In CPUz at idle it reads as 1.472v. when loaded it reads 1.44v
is this too mcuh?
should I step back???
nah its still not stable. Blue screens in UT3.
I don't know what else to do.
What about the CPU PLL voltage, FSB Termination voltage??
what are those?? and will they benefit from an increase???
You might need more FSB termination. What FSB are you running at? Either way you can go up to 1.30v FSB termination.
You really shoudnt need any more PLL yet. I would strongly recommend leaving that at the lowest setting.
You might benefit from extra FSB term. Since you have a 65nm chip you can crank the FSB term all the way to 1.5v without worrying about damaging the chip. You will have to experiment with this a little.
It is possible you might just have a poor overclocking CPU. I know I had to push the voltages on my E6600 much higher than others, and thats just the way it is sometimes. These are the settings I needed in BIOS. Different CPU and mobo, but it may help.
vCore 1.525v
VTT, FSB term. 1.55v
NB 1.4v
HT 1.2v
SB 1.5v
Agreed on the CPU PLL voltage at this stage. Upping the FSB Termination might well be beneficial; esp since you don't seem to have touched it and it may be terminating your OC. As mentioned, your FSB specs would be worth knowing.
Also, you might try lowering your RAM frequency to 800MHz. Sometimes this gives a much better OC.
1 - 11 of 11 Posts
