Originally Posted by litho
yes connection speed to the router this is what i need its a server pc
Its not exactly double the speed. Each connection can only run on one NIC, even if they are teamed. So even if you have 2 computers with 2 teamed NICs each and tried to transfer a file from one to the other, it would still only run at regular gigabit speeds, as if each computer only had 1 NIC.
The speed increase only comes into play when you have two or more separate connections made to the server. So for example, if you have 10 computers using that server as a host for a game, the server will automatically distribute the connections between the two NICs depending on their speeds (called Load Balancing).
