1 - 4 of 4 Posts
Hello , i bought HIS ati 4890 Turbo and Unlocked it in Catalyst does that mean its now unlocked forever ? or what ?
PC Evangelist
Nothing to worry about it has nothing to do with the card just with CCC which allows you to overclock it.
Thats good ! Thanks alot
What's the highest temp for it ?
Should I keep it on 965/1050 or overclock it more
It is relockable, when I updated my CCC it undid my overclock and reverted it to locked. I don't believe there is anyway to check out the card alone to find that you OCed it if your worried about voiding your warranty.
1 - 4 of 4 Posts
