1 - 7 of 7 Posts
Nvidia Enthusiast
So like the title says windows is getting annoying with this warning i already know the drive is failing and i don't care, all im using that system for is HTPC if it dies im not worried I've got 3 others. With that said is it possible to permanently disable this warning?
Some BIOS allow you to disable SMART monitoring, usually it would be located near the SATA/IDE controller setup. That might work since it's likely that Windows is basing it's warnings off of the SMART data.
Nvidia Enthusiast
it says it's already disabled
So what I don't get is...
1. You know its failing
2. You have three others
3. Yet you still want to disable the warning message.
Just replace the freakin' drive - this solves two problems:
1. It removes the warning message by proxy of a new drive.
2. You remove a failing drive which will cause more problems than just a warning message.
Nvidia Enthusiast
I will replace it eventually i just don't have the time right now and its annoying seeing it every 10 minutes
Nvidia Enthusiast
... right
Control Panel -> Action Center -> Change Action Center settings -> Uncheck Drive status under Maintenance messages.
thanks.
1 - 7 of 7 Posts
