1 - 7 of 7 Posts
Found an excellent deal on a Linksys router
And I'm wondering if it's safe to buy it off a seller on Craigslist.
Any thing? I'm a little paranoid
Sent from my Galaxy Nexus using Tapatalk
Yes it's 100% safe to buy a used router. They can't be infected like a PC can, and with a firmware update it will be 100% patched once you bring it home and update it.
Just look for any cracks or signs of being dropped or mistreated. Other than that, you should be fine.
used is in most cases pretty good, refurbished is better.. as long as you have at least 30days warrantee so you can sus it out better is always good too
I wouldn't.
Router's tend to burn out after long use. Mainly because of the heat. However some are fine. If you are looking for an older one (linksys 54 series) for custom firmware options, you have better choices.
yeh id say as stubass ask for 30 days on it, i got my lynksys 54g second hand and had it around 4 5 years maybe at least
Usually nothing wrong with it. Say if it is suffering from overheating all i'd have to say is get a Laptop cooler and put the router on top of it and you should be fine.
The Routers are usually half price. And a Laptop Cooler is about 10 bucks.
Also they usually are tested.
1 - 7 of 7 Posts
