1 - 3 of 3 Posts
i have a couple of jetflo 140s that came with my 140XL..
if i set them on the PWM control and use speedfan i can turn them off when the pc is idling..
would it hurt the fan at all?
What should be here ?
As far as i'm aware, you cannot turn them off if the system is on or idling. You could turn them down to the lowest rpm. But even then, then would be silent to not be noticed.
if i put them around 35% they stop spinning..
1 - 3 of 3 Posts
