is Kuma worth upgrading to?
876 Views 10 Replies 9 Participants Last post by  BlackOmega
I have seen a various amount of topics on the forums about people upgrading to Kuma and I am trying to decide if it is time yet.
I currently have a BE-2400 aka Brisbane 4400 which I bought brand new for 32 shipped off Newegg and its been a great little processor but the Phenom Series has me thinking.
Should I get it now or should I wait till the price falls some more?
1 - 11 of 11 Posts
it depends on how much you want to spend and or how long you want to wait
kuma dropped its price from 75 to 59 i think it will drop more when april rolls around... if you have $65 yes kuma is good
it has a huge cache which makes it better than any other x2 non phenom amd CPU
if you're on a budget, i guess. it'll give you more than 20% of performance boost from your current in terms of clock for clock. and you can oc the kuma more.
but i highly suggest you add $50 and go for an ph2 710 tricore at least. it will give you a lot of performance increase, and a smoother experience since the extra core will be the one handling the background apps.
I would agree with the two above me,
if you are satisfied with your system for the time being - or you can manage using it for another month or two (although not as much fun), I would say see where the prices are in that time.
I use the Kuma, and I like it for the price/value, but since you already have a 2400 @ 2.9ghz, I'm not sure if dumping another $65 into a Kuma for marginal performance increase would be worth it. If I were in your shoes, and price was a factor, I'd probably hang on to what I currently have for a bit longer and, as gerikoh said, pick up a ph2 for better increase in performance for your effort/money.
yeah, go PHII if you are going to upgrade.
Or maybe look for a 9850 or a 9950 used for a good price.
It's probably not worth it. I'd wait a little bit and buy a phenom II 720 if I were you.
depends what you do mate. if you just want a lil boost of performance. yeah get the kuma. if you into gaming and such. 50-60 bucks more a huge amount of performance will increase.
I disagree because I think his gpu setup is bottlenecking him more than his cpu @ 2.9ghz...
I agree, I'm very happy with my 9850 and I didn't break the bank either, 137 on Newegg. Although I'm kicking myself in the A$$ for not getting a combo deal that included a Xigmatek HDT S-1283 cooler for only 7 bucks more
Save the extra money and smile when your computer speaks to you
940BE over 720 ^_^v
720BE over 810
720BE over 9850
720BE over 7750
7750 over x2 non phenoms
I'd say get a 710. If your board can handle the clock speeds, it'll overclock very well. It's basically the same thing as a 720 with a locked multiplier. Not to mention if/when you want to upgrade to a purely AM3 platform you wont have to buy a new CPU.
1 - 11 of 11 Posts
