OK so the past two days I've been working on OC'ing my sig rig, using this guide:
http://www.overclock.net/intel-gener...uide-p67a.html
So far not impressed with my chip. Maybe I got the turd of the sheet here I dunno....
To get 45x "stable", it's taken me 1.39v Vcore, 1.08v QPI/Vtt. With LLC enabled. I did manage to get 7 hours of P95 out of those settings overnight, temps in the 60-61C range. So I left it run while I went to work, and came home to BSOD and 0x101. Grrrrr. So it survived at least 7hrs, but not 16hrs. Oh and it idles around 36-38C. Which I thought seemed kinda hot for being under an XSPC Rasa 240 kit.
Any lesser voltages than above and it fails within 5 minutes of Prime 95. Same thing with the above voltages without LLC enabled. Literally within 5 minutes P95 gives me BSOD and 0x101. Funny thing is, I'll run LinX for 10 minutes or so at lower voltages just fine. Temps at 64-66C. But then 2 minutes of P95 and BSOD.
Anyone got any ideas? I'm new to this and quite possibly I'm missing something? Seems like a lot of voltage and a lot of heat for a relatively MILD 4.5ghz.
Batch # L102B486, if that matters. Searched and didn't find any particulars with that batch
