1 - 20 of 26 Posts
I'm looking to get a GeForce FX5200/FX5500 to play World Of Warcraft and i was wondering if my computer is compatible with it? I'm currently only using my onboard craphics card.
My systems specs are as follows:-
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 1 (2600.xpsp1.020828-1920)
Language: English (Regional Setting: English)
System Manufacturer: Dell Computer Corporation
System Model: Dimension 2400
BIOS: Phoenix ROM BIOS PLUS Version 1.10 A05
Processor: Intel(R) Pentium(R) 4 CPU 3.06GHz (2 CPUs), ~3.1GHz
Memory: 766MB RAM
Do you guys think this will run World Of Wacraft and is the GCard commpatible?
Read Only
Im sure those cards are AGP, so if u got a agp slot then ur fine if not make sure you purchase a pcie graphics card and if u can go the extra money for a 6600 get it. Those cards are not enough to power newer games but wow would work fine with them.
I wouldn't get either of those cards.. heard they're the about the worst series nvidia made, lol.
So I'd lookout for a diff card, maybe spend a few bucks more, but you'll get a way better performance for it..
At the moment i only have 256MB or RAM but i'm upgrading with another 512MB slot tommorow. I bought a GeForce 6200 a little while back but it lagged my PC when i put it in. Was that due to the amount of RAM i had at the time?
you need to contact Dell or take a look at your manual and find out what type of expansion slots your computer has. Some of the lower line Dells only have PCI slots.
if you have an AGP slot then you can basically get any AGP gfx card
if you have PCIe then you can get any PCIe card
but if you don't have either of those slots you're stuck w/ a PCI card.
Well, I did a search on Google for "Dimension 2400" and from everything I see there is no AGP or PCIe slot.
So you're stuck with onboard GFX unless you want to try a PCI GFX card.
that's what I thought... my roomate last year had a cheap Dell that didn't have an agp or pcie slot and he had to get a pci slot.... he was super pissed at Dell for not putting a graphics slot in... but I just told him... Dude, you got a dell... LOL! but seriously, you need to look at the specifications closely at all cheap pre-built computers. a lot of them don't have pcie or agp slots
welp then you need to get a PCI gfx card. there aren't any 'good' ones but some of them will be better than integrated
I did have a GeForce 6200 but i had to sell it as when i installed it on my comp my CPU usage shot up and my Computer was really laggy. Is their a specific amount of RAM you need to have in you're computer when you use that graphics card?
no... actually your cpu usage should go down when you use a real gfx card. there must have been something wrong.
update your bios and your chipset drivers... and when you get a new gfx card install the newest drivers not what comes on the disc
Discussion Starter · #12 ·
You're sure it is comppatible with my computer? I'v seen alot of other people with the same problem aswell.
Well, there are no PCI Geforce 6200. There is 5200, but not 6200.
Your best bet would be get a GeForce FX 5200 or a Radeon 9250 since those are the two best PCI GFX cards out.
You'll be paying 50 to 60 GBP on one of those.
Administrator
Just a warning, even with 512MB of RAM you will still get lag in World of Warcraft especially in lagforge (IronForge).
Discussion Starter · #15 ·
I'll actually have 768MB when i upgrade tommorow as i already have 256 ^^
I don't even attempt to venture to IF as i am now. I try to stear clear of all the main cities....
Administrator
Yes there are PCI 6200's. Here is the most popular: http://www.bfgtech.com/6200_256_PCI.html
That card is one of the best PCI cards avaliable, however it is unfortunately still fairly slow. It will play most of WoW fine but don't expect super good performance in Alterac Valley
- my laptop has trouble in there badly.
1 - 20 of 26 Posts
