1 - 8 of 8 Posts
Screen Res: 1600x1200
Ultra high settings
4x AA
everything else on
21 48 frames renderd in 56.3 seconds=40 fps
for my system specs is the right?
also when i try and use it on 8x and 16x i only get around 20 fps does this sound right for what my system specs are?
Originally Posted by Zippy476
so if i get another gig of ram and a new cpu i should be able to play the game with like x16aa
You dont need either of those. Overclock that FX-53 to around 2.8ghz if it will run stable there, which it should. Once you do that, your performance will increase a lot. You can also overclock that videocard which will help too.
1 - 8 of 8 Posts
