I have a ausus xg32vq monitor for about 3 years its had an issue in the last year where if its turned off for a day or overnight it gets lines all across the screen. Which eventually go away after a few mins. Other then that no issues, I recently bought a new desk which required longer cables of which I assumed my new 3m dp cable was faulty as sometimes it would drop to 120hz and and any red colors on my monitor become slighty more blurry. I replaced it with a new 2m dp cable and the issue just happened again.
The monitor menu shows 144hz and nvidia control panel says its 120hz. Turning the monitor on and off fixes the issue ive also moved the dp cable to another connection port on my gpu. My evga 3070 is fairly new it holds top place for all the records for my setup and top 100 against all other 3070 cards. Ive had no crashing issues with it and the only recent change ive made is added mining to the mix at 60% power while im using my pc and 50% when im not using my pc.
I assume its the monitor i never bothered to rma it or is this a gpu issue? If i remember to ill take a photo of the lines next time it happens it usually goes away pretty quickly especially on hot days. Almost seems like the monitor needs to warm up to work.
