1 - 3 of 3 Posts
the only multiplier i can find is the one in my bios that says computer multiplier is that the correct one or not
you should have two options. an HT multi (5x, 4x, <b>3x</b>, 2.5x) set it to 3x<br><br>
then you should have your CPU multiplier which says [startup]. you need to change this to however far you want it.
1 - 3 of 3 Posts
