1 - 20 of 33 Posts
So, every time I try to turn on my comp, it turns off 1-2 seconds later...
It has done this with two motherboards. The gpu and psu are fine as they have ran in a different system.
· Engineer of Malcontent
start bby taking out every single component not needed to boot to bois(HDD,CD drive, stuff like that). That means unplug all external things as well that are not needed to boot. try to turn on again and if still nothing reset cmos. still nothing try different ram sticks then post back.
My new one would not boot with a Certain CD drive plugged in. Computers have weird issues sometimes.
Reactions: townending
Originally Posted by munaim1
Bit more info would be great, like what mobo are you running? What psu? Is it your sig rig minus a few things?
Its a whole different rig
CPU: i5 2500
Mobo: Asus P67-M Pro (also used MSI P65..... same thing)
Ram: 4Gb DDR3
PSU: 650W ultra LSP
GPU: GTX 460 1Gb
HDD: WD 500GB
Discussion Starter · #6 ·
Originally Posted by nagle3092
Clear CMOS and try to boot.
I never made it to bios, never got past 2 seconds of on time
· Premium Member
Theres a jumper on the mobo that you have to move its down next to the front panel connections, look in the manual. Do this first as theres no need to take out all your components when this could solve your issue.
· Premium Member
Make sure all connections are in place, i would try using all the basic hardware needed to post ie. one stick ram at a time and as suggested above clear cmos.
EDIT: It seems that clearing the cmos can be a toughy sometimes as the jumper setting doesnt sometimes register, this is the best way I found to clearing the cmos and it works everytime:
Unplug ac
Press power button to ensure no power remins in the rig
Take the batter out
Move jumper to the right
Wait a minute
Move jumper back to default
Put battery back in
Plug ac
Power on
Check the contact between the heatsink and cpu (sometimes it feels seated but it isn't), i've seen PC's turn off that quick before because of it (usually a heat issue) but it shouldn't really get that hot so fast but check anyway. Also as others have said, check every single connection on the mobo etc... good luck
Discussion Starter · #11 ·
tried each stick of ram, gpu is fine, psu is fine, this is 2nd mobo that did same thing
anybody have any idea where the clear bios jumper is?
Discussion Starter · #12 ·
Hmmm, tried the cmos jumper, the memok button and yeah... still nothing
· Premium Member
It should be right next to the front panel hdd led, power and reset connections (bottom right of the board). Its a little blue cap that sits on 2 pins and there is 1 pin next to the cap. The jumper needs to get moved to that pin, like I said your manual will help you.
Did you let the jumper sit on there for 10 seconds?
If its two different boards I doubt its the jumper fix thats gonna work.
What all do you have plugged into the machine? just keyboard? the power and keyboard are the onlythings that should be plugged in. Heck even take the keyboard out on a try.
Discussion Starter · #15 ·
gpu
1 stick of ram
cpu fan
· Premium Member
EDIT: HOLY ****IN NINJA'D
Discussion Starter · #19 ·
Originally Posted by Lex Luger
Its your cpu
ouch, did you overclock it, doesnt matter you should be able to get rma, sorry bro, but who knows, maybe youll get a golden chip back.
golden chip or not, this blows, it was for a friend and its been taking a while to build due to this situation.
· Premium Member
Go back to first page (sorry not on the pc at the moment) and try the method i posted on clearing the cmos, using the method i posted doesnt require you to move jumper, taking the battery is enough to clear cmos.
By the way did you try both ram sticks? Can you try a stick from your sig rig?
1 - 20 of 33 Posts
