Quote:Originally Posted by supra_rz;13158307
its dual channel obviously
Quote:Originally Posted by Shomiyamu!;13158308
If it's set at unganged, that is dual channel.
Thanks everyone,one other thing can this cheap ram be modified,ie. timings/speeds?Originally Posted by labbu63;13158334
it is dual channel
It is running dual channel, but the unganged part doesn't matter. It can be dual channel either way, ganged just means the CPU works in 1 x 128 bit while unganged is 2 x 64 bit for accessing the memory. For general use unganged is better.Originally Posted by Shomiyamu!;13158308
Yes, you can adjust the settings, both frequency and timings.Originally Posted by Heavy MG;13158387
Dunno why AOD sees my ram as single channel.
yes the ram speed and timings can be modified in the BIOSOriginally Posted by Heavy MG;13158387
RAM slots #1 and 2. Slot 1 is blue,slot 2 is white.Originally Posted by xd_1771;13158483
What slots are the RAM in?
Ah,I will move the 2nd stick into the blue slot then. My rig should feel faster as I was running single channel the whole time.Originally Posted by xd_1771;13158572
Same coloured slots is the way to go. Move the one from RAM slot 1 to RAM slot 3 (4th slot). Then it will run in dual channel. At the moment it is indeed running in single channel, and why CPU-Z reports it as dual channel stumbles me as that would be wrong. Dual channel requires same coloured slots.
