Is my mouse pad good enough?
3046 Views 41 Replies 22 Participants Last post by  mjpd1983
Bought this cloth mouse pad a while ago and it seems fine, but I just wanted to check if it would be fine as far as accuracy for a mouse, I looked at a razer one which felt somewhat bumpy, and mine is smooth. Unfortunately, I can't seem to find it using google, on the mouse pad it says warzone with a lightning bolt in the middle, and battle for honor underneath it, i searched that but got nothing relevant back. Besides that its just plain black. If someone knows what I'm talking about and has any opinions/reviews of it, I'd really appreciate it.
1 - 20 of 42 Posts
Originally Posted by JedixJarf;13116042
I haven't used a mouse pad since optical mice came out
Well my desk is a piece of crap.
I recently bought a Steelseries I-2 glass mousepad. I like it a lot. It is perfectly smooth and seems to have much less friction than any other surface I have used for a mouse before. It also came with low friction pads for the bottom of the mouse that seem to be much more slick than the ones that came on my logitech mouse. I don't think it really makes the tracking any more accurate but it certainly offers a silky smooth surface to operate on. I also chose it because it can't wear out. The back side of the glass is painted but the surface you operate the mouse on is bare glass. I figure this mousepad will last forever as long as I don't drop it...
They say this mousepad is not for laser mouses though. Optical only. It also might be discontinued. I just went to the steelseries site and it says out of stock. Some other sites are out of stock as well. You can probably hunt one down if you try though. Who knows, they might be coming out with something better.
I haz Hilary Duff Mouse Mat.
I have a smooth gaming pad (not cloth) and it's nice! I like the smooth texture better than the rugged one because I run and gun in FPS games so I like the smooth gliding.
If you don't notice an issue, then don't worry about it.
Concurrently, with optical and laser mouse technologies having a mouse pad is a matter of personal preference. Does it increase the accuracy of your mouse movement? Debatable. Have I ever noticed a difference? Nope.
I'm slightly biased since I'm not a gamer though, my rig is used predominantly for [email protected], research projects, light Python programming as well as intensive multimedia applications (i.e. 3D modelling)
Mouse pads are meant to help the track-ball in older mice move around the mat without giving the end-user terrible headaches.
Well there could still be a tracking issue even if I don't notice it right? So does no one know what brand my mouse pad is? It just seems weird that I cant find out. Also, do hard mouse pads have a lot of friction, like a wooden desk would have?
I blew my money on a ss 9hd pad and i like it alot.
Ive gone padless in the past and that worked fine too but depending on the surface it might wear out your mouse feet quite a bit faster.
I got one with soap bubbles from ALSOP? Don't even know who they are. Probably just throwing them out there as a way for free advertising.
The only time I ever wanted a mouse pad was when I was using a cellaphane wrapped board game and the mouse was being all wonky. Right now I am using the arm rest of my couch.
Whats a good quality hard mouse pad?
To answer the OP's question we really need to know what kind of mouse you are using. Whether your mouse tracks well on the pad you describe depends on the sensor it uses.
Generally, if you have a "high end" mouse it really pays to have a decent mouse pad that it performs well on.
When I used optical mice, I used cloth pads like the steelseries qck. When I finally upgraded to lasermice I started using hard pads. Generally (but not always or all the time) lasermice have problems on cloth pads.
Mousepads arereally up to someone's own preference. There really is no "best" pad. You should at the very least try and make sure your mouse doesnt have issues with it though.
I have only tried a handful of hard pads, and its down to personal preference really. But from the few I used (like the steelseries 4HD, S&S and razer sphex) I really like the razer sphex for the money you pay. However, some like the perfectly smooth surfaces, others like surfaces that are rougher and provide more control. The sphex is sort of somewhere in the middle and to me feels just right.
Going to be using a razer abyssus.
Originally Posted by Domino
all cloth pads suck.
How so?
How so?
It comes down to the friction caused by the cloth. Unless your happy with it, its fine. But the added friction caused by the cloth just makes you have to work more to move your mouse and fundamentally delays your reponse or efficeny over time.
Most mice are going to feel crapy just because the pad itself makes it undesirable. A solid wood or opaque surface desk works the best when compared to a cloth pad. Remove it, and your mouse would feel so much better....if the desk is good anyways and not made of glass.
You want a mouse pad where your mouse litteraly glides on a near frictionless surface. The only friction you should have in from your own palm touching the surface, not from the mouse itself. Physically, there will always be friction, but less the better.
That's your own Opinion.
Playing style and Control are factors that you leave out.
1 - 20 of 42 Posts
