1 - 14 of 14 Posts
D-TEK FuZion v2 Extreme Performance CPU Block
Regular price: $69.95
Sale price: $59.95
Swiftech MCRES Micro Revision 2 reservoir
$24.50
Dtek dB-1 Compact 12v DC Pump w/Tach Sensor
Regular price: $49.95
Sale price: $43.95
Swiftech MCR320-QP Quiet Power 3X120mm - Black
MSRP $63.95
Our Price $47.95
Tygon R3603 3/8in. ID 1/2in. OD Laboratory Tubing # AAC00027
pad
$1.55/foot
Feser One F1 Cooling Fluid - UV BLACK - 1 Liter
Regular price: $19.95
Sale price: $16.95
Petra'sTech PT_Nuke Concentrated Biocide (10mL)
$2.50
Herbie Clip® Nylon Hose Clamp Size D - Black
$1.70 for 10
Black Nylon 3/8 ID Y Splitter
$1.25, 10/$10.00
Logisys Dual Blue 4 in. CCFL Light Kit
$6.95
Thermaltake 120mm Blue LED Smart Fan
$13.95, 5/$55.00
Scythe 120x25mm SlipStream SY1225SL12SH - 110 CFM
$8.95, 5/$40.00
Sold my old one!
I have kept back my chipset block
Overclock? What?
Originally Posted by Juggalo23451 View Post
prevents algae and other growth in your coolant
Yeah, exactly keeps biologicals out it's a biocide.
I agree, you should get Yate loon fans
Also, if you dont mind having UV blue, red, pink, purple Feser one coolants then check this link out: http://www.ncixus.com/products/28353...6/Feser%20One/
You could also get other colors(like I mentioned above)
Also, I think you dont need PT nuke if you are using a pre-mixed coolant like the Feser one, but I am not very sure though. If you read through the description, it tells you that it prevents the growth of algae.
But everything looks good IMHO..
Originally Posted by coolerM
What should I use in the loops if I use a TEC or place ice blocks on the rad??
Some type of polyurethane sealant spayed on the mobo for when condensation builds up.
1 - 14 of 14 Posts
