1 - 3 of 3 Posts
Hi, Im planning to purchase a Enermax NAXN 80+ 600W
http://www.enermax.com/home.php?fn=eng/product_a1_1_3&lv0=1&lv1=42&no=148
Is this PSU a true 600W? Im really on a very tight budget, and I came upon this PSU. Is this PSU good? Does it gives at least 500W true power? Is it enough to power this CPU?
Gigabyte GA-M68MT-S2P
AMD Phenom II X4-965 BE
Seagate Barracuda 7200.10 500GB
Kingston DDR3 PC1333 4GBx1
HD6770 1GB GDDR5
Sony 24x Internal DVD
Is this enough to power this build? Thanks
It's perfectly fine.
Enermax is a trusted and very reliable brand (up there with seasonic if I dare say)
You can get away with a reliable 450W PSU if you want - since you're tight on a budget.
600W is enough for 6770s in Crossfire.
HD6770 1GB GDDR5
It's a 500W unit going by the 12v rating, and it's a lot more than you need.. what's your budget and where are you buying from?
1 - 3 of 3 Posts
