Is my PSU the cause of apparent voltage fluctuation in CPU-Z
724 Views 3 Replies 4 Participants Last post by  Clockadile Dundee
In BIOS it is set to 1.425, and in CPU-Z it says 1.464 with small fluctuations occasionally....for example from 1.437 to 1.478. Is this a normal occurrence, and would that much fluctuation cause my PC to crash under load? The PSU has had very little use since I bought it new. Thanks for considering my issue. Any advice or suggestions or questions?
1 - 4 of 4 Posts
no, that is your cpu or motherboard. Im not familiar with amds, but intel cpus have "vdroop"/"load-line calibration", and it protects the cpu from voltage spikes and dips by artificially raising the voltage under load. Also, with the i7 cpus, when the cpu gets too hot, it raises the voltage to keep it stable. A slightly higher voltage reading when stressing the cpu is normal, like 0.02v, but im a stranger with amds so hopefully somebody else can jump in
I had this problem before. It stopped when I got a board with VRM coolers. Try buying some ramsinks or minheatsinks whatever they are called and sticking them onto the VRMs.
1. Like MrLinky said, vDroop/Load Line Callibration. In the BIOS, it may have a setting like vDroop: enable/disable, or LLC enable/disable, if you enable Vdroop, LLC is disabled, and if you enable vDroop, LLC is disabled, they are like two sides of a coin as far as the BIOS setting.
2. There will be the actual vCore, say, then there is what you set in BIOS, and what the software thinks it is. These are usually all different, from my experience comparing them with a Fluke digital multimeter.
3. From what I have heard, you may indeed want to have vDroop enabled at that vCore.
1 - 4 of 4 Posts
