1 - 17 of 17 Posts
ya..thats before i overclock it.. i have the exact same timing as urs
after i overclock it..thats how it shows..just want to know that.does it look stable..or weird?
erm..i change the DRAM freq Multiplier to x8.00 instead of x6.66
8.00x200 = 1600mhz for my ram..i tot that is gonna be faster? lol
and
6.66x200 = 1333mhz.
so after i change to 1600 the timing cas go 11-11-11-29
at 1333 i got 9-9-9-24
which one better lol
Can't see anything in the second pic...
You need to manually set your timings and DRAM voltage according to the manufacturers specifications.
Discussion Starter · #12 ·
u mean how according to manufactures spec?
set the timing alll manually? in BIOS?
Yes. Most sticks have a sticker on them that usually says what they are to be running at, like: 9-9-9-24 @1.7v (just an example). If it doesn't say on the sticks themselves, then look for it on the package, if not on the package then find them on the manufactureres website. I'm sure you can get those operating alot faster then what your getting now.
Discussion Starter · #14 ·
ok got it...thanks for your help...
i set 1600mhz thats the factory default timing.. and get better result too.
9-9-9-9-24
hehe..it works now. 1.65V
1 - 17 of 17 Posts
