1 - 8 of 8 Posts
Hello people
I recently bought Samsung 840 Pro 128 GB and I updated all my drivers and enabled AHCI or whatever is required in the bios. This is first time I am using SSD and ran this benchmark. I am not sure If I am getting full potential or I can still tweak it further to make it faster.
Your comment will be appreciated. thanks.
A different driver would be able to get a higher score, much higher really bud. Just noticed that you have a 128 gb version so the numbers will be a little less but should be higher than you currently have.
I am using the achi driver from the new 12.0 irst driver.
Storage Nut
Edit: Install the IRST driver and you will be set.
Bud.. I have Gateway DX4860-EF12P model and here is the webpage for specs.
http://ca.gateway.com/gw/en/CA/content/model/PT.GCPP2.021
I think it has Intel H67 Express chipset. I am not sure if that is same thing as motherboard. I downloaded all drivers from Gateway website. Will you please point me the right driver which I need to install in order to boost the performance. Thank you very much for your help .
Auto check: http://www.intel.com/p/en_US/support/detect?iid=dc_iduu
Otherwise: http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=2101&DwnldID=22194&keyword=Intel+Rapid+Storage+Technology+%28Intel+RST%29&lang=eng but check if your AHCI controller i supported http://downloadmirror.intel.com/22194/eng/readme.txt
Discussion Starter · #6 ·
1 - 8 of 8 Posts
