1 - 20 of 23 Posts
Hi Commander Kool,
The vast majority of people run the "1M" SuperPI Calculation for performance comparisons, or at least they do here at o/c.net. Try running the "1M" calc and post your screenshot of the result. My system does "1M" in 38 seconds with my 3.6GHz 24/7 O/C. If you can get lower than 34 seconds you'd be doing very well imo.
Highly-Annoyed
its pretty good,i get about 32min on my 32m calculation, but yes run you 1m calc. and it will be easier to compare...
40 sec is good... on 1m i think i get 50 sec... so your doin pretty good... better than me
damn i gotta get a better system, my 50 sec 1m is embarrasing!!! grrr....
Discussion Starter · #8 ·
Originally Posted by ThaWaxShop
yeah super pi 1m is good to compare i get 29 sec with my crappy ram by wed i should shave a couple secs off with the new stuff.
Are you trying to crush my spirit, Mr. show off?
J/K nice job man.
Originally Posted by Commander Kool
Is this a pretty good score?
Good for your proc, this is what I get:
For some reason, which I do not know why, I don't score as well as I used to in super PI, I used to get 32.424 secs 1M, but one day, it just didn't go below 33ish.
I need new RAM also.
this is what i get... and it sucks really bad!!! what can i do to improve!???
disregard all scores except the 1m and 32m....
Are you Oc'ed ?
I can get 40 seconds with a 3.150 prescott
If you're not overclocked try to get to 3.5, that should be an easy oc (15%). That should bring it down. Also make sure all unnecessary services, and programs running in the background are turned off. Good Luck
Originally Posted by Snip3rWarrior
Are you Oc'ed ?
the best i got with my 3.0e @ 4ghz was 32 sec
Originally Posted by Dannyhaddon
to even get 26-27 you need 5ghz,
I can probly just get mine below 29-30
lol, this thread is old, Danny.
Ehh... if you have a nicely overclocked AMD CPU, time in 20sec. is possible. I think one of the people on the forum got time in 20 sec. range.
Thus, you don't need a 5 Ghz CPU to achieve that.
And AMD people.... you're all mean when it comes to PI!!!
EDIT: I get 37 sec, BTW... yay.
1 - 20 of 23 Posts
