1 - 5 of 5 Posts
Hey Guys Im New to this site figured id make my first post a question lol. Im in the process of building what i think will be a decent Gaming Rig Im just waiting on Newegg for a few parts but my system is as follows
ASRock K10N78D MotherBoard
AMD Phenom II Heka 3 Core 3.1ghz (4th core Unlocked)
OCZ 8GB DDR2 800mhz
Saphire Radeon 5770 Video Card
2x 500GB SATA Seatgate Barracude HDD 7200 RPM
Rosewill Armor Case w/ 6 120mm Fans and 2 80mm Fans
680 Watt EchoStar PSU
Samsung 24x SATA DVD Player/Writer
I Will Be Running Windows 7 64 Bit
The Main concern here is how well will this system fair in ffxiv as i knbow it is a very system demanding game. and also how High can i Overclock the Memory, GPU, and CPU i want them as high as they can stabily go i have the Scythe Katana CPU cooler on it so and with all the fans i have head shouldnt be a problem. the motherboard is equipped with alot of overclocking features also let me know you oppinions. THANKYOU
FS19 Addict
I think you should be fine with that set up just depends on resolution you run it at. As far as OC goes on the hardware check the overclocking sections of this forum AMD and ATI lots of info use the search function it helps me a lot. All hardware is different so highest OC will be up to your ability, knowledge, cooling and your parts.
1 - 5 of 5 Posts
