The 550 is underpowered for your system. Get a 560ti. Or a 6950.
yeah... then that leaves around 200 for a card...Originally Posted by amstech;12976551
You can get a good 600W or so PSU for $50-$65.
No it doesn't. The Corsair 450 watt will power through anything up to a GTX580.Originally Posted by amstech;12976374
Youre PSU needs to be changed.
Great little CPU though, I would be looking at a 5870, 1GB 6950 or 560Ti.
^ This is good advice.Originally Posted by pioneerisloud;12976627
You don't NEED a 600w PSU for something as power easy as a 6950. You could EASILY run a GTX570 or HD6970 off that PSU you have now.
Ignore the PSU guys saying your PSU needs changed, they clearly don't understand power draw.
Spend your money on a better card. 6950 2GB, 6970, GTX570, GTX560...all good cards, all will work FLAWLESSLY with your current PSU and the rest of your system.
No it doesn't. Your 570 needs a GENERIC JUNK 600w PSU. The Corsair 450w PSU has more power than a junk 600w does. Of course, I'm talking to somebody who has a mediocre 600w PSU anyway, so you clearly don't understand what a quality PSU is capable of.Originally Posted by amstech;12976675
Well It may power more then I think but all the way up to a 580?
My 570 at minimum needs 600W/550W.
Must be one hell of a 450W!![]()
Simmer down now boys....Amstech you're wrong. Listen to Pioneer cuz he knows what he's talking about.Originally Posted by pioneerisloud;12976693
He's saying that power supply will be fine for everything except for a GTX 580 and a 6990. Get whatever card you want but when you go to SLI you will probably need a new power supply.Originally Posted by HardheadedMurphy;12976708
so what you are saying is... go for the a better card than the 550 and drop the psu till I am ready to sli?
What I'm saying is definitely buy the better card. You have absolutely NO reason to upgrade the PSU until you go dual GPU (crossfire or SLI). Your current PSU will handle just about any single GPU card on the market (I personally wouldn't trust a 480 and 580 on it, but anything else would be fine).Originally Posted by HardheadedMurphy;12976708
