1 - 10 of 10 Posts
i just mount all my things to watercool and i dont know if everything is alright there is some picture that i have take to show you guys, on the last pic i have some bublle on the left side where the water dont flow has much . is that normal
The inlet and oulet are wrong on your EK Supreme HF.
If you were to make a modification on the tubing, I would put the optical drive at the very top and then lower the reservoir underneath it. Then have the tubing going straight down into the pump. You could also use a special fitting like this to attach the two.
thats is weird that the inlet and outlet are wrong because i did exactly has the plan says on the instruction guide :S whenn i look to the plan i found weird that they says inlet is a the right because the inlet is supose to be the one thats the most on the center i will corect that:)thanks for the tip with the optical drive i will try that
Originally Posted by Tweak17emon View Post
the tubing should NOT fold at all. that will heavily restrict your flow and pressure.
I did some change i put the optical drive on top an the pump right above the resevoir the temps are good i thin im at 3odegree idle and 6o load with 5ghz and 1.48v with prime 95 i put some zip tie where the tube fold so it fold less then before but i think i will need some 9odegre compression fitting
1 - 10 of 10 Posts
