Is nickel plated water block better then full copper?
2378 Views 13 Replies 8 Participants Last post by  DuckieHo
Is nickel plated better then full copper?
nickel plated water black
http://www.frozencpu.com/products/73...el_Plated.html
copper one
http://www.frozencpu.com/products/73...0_GX2_SLI.html
1 - 14 of 14 Posts
copper is better.
No. No matter how well nickel conducts heat, you are adding a layer. Now, it may not make a huge difference, but copper alone is better than copper plated with nickel as far as heat conduction.
you wont notice much of a difference... if you like the looks go for it, but in theory copper is a little better... the nickel plated block would be the preferred one though if you have any aluminum in the loop like a koolance radiator, the nickel prevents the copper from coming into contact with the aluminum trough the coolant, which would cause galvanic corrosion.
The nickel also prevents discoloration of the copper. It helps for looks.
yeah, i forgot to mention that, thx for adding.
they're about the same actually for 2 reasons
1 most copper blocks are coated so they dont corrode. Fuzion even tells you this. So results are simmilar to coating with nickel
2 If you dont coat it to prevent corrosion it obviously corrodes which reduces the performance
nickel plating should give you an excellent surface and not corrode any where near as fast as copper
Nickel is far better. For those that say nickel add a layer, you should see what a copper block looks like without proper maintenance. Corosion is also a layer and that's ultimately what you will get.
I have both the g92 copper and nickel and I want to coat the other copper one because it's a hassle to clean it.
How much performance is lost due to the layer of corrosion?
none
Nickel also looks better
I am going to get a nickel playing kit from caldwell and plate my ek supreme and the mosfet blocks
Black Delrin is cheaper and not to bad on the eyes.
1 - 14 of 14 Posts
