No, don't bother with it. The Autotune is too slow in reacting and increases clocks too fast when it does it's self-testing. You usually will end up crashing or locking up your system. A slow small manual approach with either MSI afterburner or AMD GPU Clock tool, work best.
I'm really new to overclocking, but I read on Guru3D that novices are recommended to add 5% of the original speed on each time. Also, I could be wrong. I'm just as new as you.
And the Crysis benchmark is what you should use to test it.
It's alright but it tends to 'exaggerate' overclock stability. Atleast it did that when they just released the auto-tune. I haven't used it in a while as I just set my OC manually.
940/1040 is the overclock, as in, core/memory speed.
