1 - 13 of 13 Posts
If your mobo cant overclock dont your think maybe you should get one that can overclock and another stick of 512 kingston ram.
well don't buy Corsair. they have some of the worst support ever, plus they are getting out of the high end RAM business.
both OCZ and g.skill are better performance wise and they're cheaper
Me or him?? You should really consider getting a new mobo and 1 more stick of 512 kingston.
What fsb are you running ?
Putting high end RAM in a sytem that will never utilise it is pointless.
Discussion Starter #7
Him, I want 2gb before i make the jump to amd and pci-e. Im running 166 mhz , 2700. My timings are 2.5-3-3-7. You can change the timings and stuff in bios but you cant change anything for the processor unless its just a 15 mhz fsb increase. The max for the mobo is 3200
You could try..this..from G.SKILL for US $245.00 it has been getting good reviews and is hard to beat at the moment for all but high fsb's over the 250MHz mark.
It will be my 2x1024Mb upgrade choice this month.
cheers
Originally Posted by HotDog
This would be a good Choice for you...
G.SKILL Extreme Series 2GB (2 x 1GB) 184-Pin DDR SDRAM Unbuffered DDR 500 (PC 4000) Dual Channel Kit System Memory - Retail
http://www.newegg.com/Product/Produc...82E16820231021
And its PC4000 DDR500.. and it Cheaper then the DDR400 PC3200 version
Yes the HZ series in 2 x 1024Mb is another option but only if you are looking at fsb over the 250MHz mark.
If you are around the 250MHz or lowewr the HX series I linked to will perform alot better due to the tighter timmings and lower voltages. The HZ is said to be quite sloppy below 250MHz. If you wish you can check out a review of the HZ series..here.
There is also the ZX series in 2 x 1024Mb modules..here..for US $195.00 but it is not up to the performance of the HX series.
cheers
1 - 13 of 13 Posts
