Originally Posted by GT! umm my case fan? |
Originally Posted by GT! Lol Thx For Telling Me Imma Get The Tower 102. Lighter And More Efficent I Think And Comes With A Nice Fan On It |
Originally Posted by spookedjunglist How many people in here own a tower 112 that have posted you need to support it? ATVkid and i both have this Cooler, and believe me the people at thermaltake thought of this... there is a big bracket that goes on the back of the mobo with arubber pad to allow the weight to be distributed on the back og the motherboard... oh and i tightened the crap out of it ... i tightened it so much the metal bracket for the top was bending a little bit : nothing broke... the 112 cools very well, and my case might be a rare one, but 3.2e running at 3.9ghz is pretty good on air, lando only got to 3.83 on watercooled with a 226watt tec. but i think he just got a bad chip or something.. idk if the tower112 will fit in the dell case but its made to barely fit in a standard atx case with a 80mm fan in the side so i think that it should fit in a dell |
Originally Posted by adas123 if u are getting the mobo i showed u, then it should fit in there. it fits sideways in my midtower, but im not sure exactly how big that case is. i guess u wnat to use it after all. but it is one heavy mother, so u want to make a little support for it above with some string and zipties |
Originally Posted by Bindusar GT!, are you replacing the mobo as well or keeping the Dell board? If you are replacing I won't bother checking mine...jw. |
Originally Posted by ATVkid*AFZ* i just looked on my dell mobo, they DO seem to fit... not sure about it though, but they seem to be in the right place, there are mouting holes, i don't know if they are the correct dimensions, but they're there...all 4 of them... |
