Originally Posted by Darren9
Probabally not without some extra hardware - a signal splitter and some sort of video capture card that supports a format your GFX can output.
Can't i just just share my screen or something on the other computer?
I'm sure you can. You may have to use some sort of remote connection software that may have that built in. Alternatively you can use screen capture software in conjunction with remote access software.
Your probabally correct, I didn't consider remote access over a network. That would prolly work with some screen capture software running on the second PC. I used one once to help a guy on here - it was pretty low res though.
well it depends on what youre using to record. what program are you using? it its using up your resources. try using debut video capture. its pretty slim and doesnt use a whole bunch of resources i think
i have always thought about this once a blue moon my idea was to use and older card with svideo for the out put (the compy being recorded) and a tv tuner with svideo on the recordING compy. so long as the software lets record whatever is in the svideo in you could even do bios videos and screen captures.
