1 - 2 of 2 Posts
I am waiting for GTX 1070 or Polaris 10 GPU so I don't have discrete graphics card right now.
System Spec
i5-6500
ASUS Z170-A
G.Skill Ripjaws 4 2x8GB 3000MHz CL15 @ 3200Mhz CL13-16-16-32-2T 1.45V with some manual sub timing
Is ther anyway to use IGP If I flashing BIOS to unofficial non-K BIOS from der8auer website ?
On most boards, you can only use the Intel GPU if you are not doing any BCLK overclocking. Any BCLK setting higher than ~102 MHz will probably lock up when booting up. I have a different Asus Z170 board running an unofficial bios and the core temperature sensors, C States, iGPU and AVX instructions all work normally when not overclocking. At higher BCLK values, none of these work.
1 - 2 of 2 Posts
