Originally Posted by scottsee
I've been under a rock with my XP laptop for a long time! Is there a built-in command line interface like XP & Server 2003 WMIC implemented for Vista/Win 7?
Thanks
Plus, Scott: according to your Signature, you have Windows 7. So, you could have done the same thing I did. I mean, all I did was I typed
WMIC into the Run dialog box, and then I had the console (yes, I am old school and prefer the Run dialog box). But, I used Google first to make sure that I was doing the right thing.
And as it turns out, I am.
But an even
easier way is to just click Start and then type
wmic (or press the Windows Key and type
wmic). Of course, make sure you click on it or press Enter.
The reason why I was so short with you in my first reply is because your sig rig shows that you have Windows 7.
