1 - 3 of 3 Posts
I was wondering if there is any diffrence between the blue or white PCIE 3.0 slots? I will be using a single GPU setup. It seems most people put a single GPU in the blue(closer to the cpu) slot. Basically the upper most PCIE 3.0 slot. The reason I ask this is because I want to fit a pcie 1.0 soundcard into the board but I would rather not put it abover or below the GPU to try and keep both cards cooler. Or would it not hurt the GPU/soundcard to have them virtually touching eachother?
*edited to correct x3 to 3.0*
Hey I get one of these!
Both are PCI-e 3.0 x16 sockets with all 16 lanes, however it is almost always advised to use the top slot.
Also, PCI-e slots come in 4 sizes, none of which are x3.
PCI-e x1
PCI-e x4
PCI-e x8
PCI-e x16
They refer to the number of lanes the slot has available. Typically x8 and x16 both use a x16 sized socket, but some lanes may not be in use.
Can you please explain why it is advised to use the top slot?
Also, I shouldn't have used x3 to represent 3.0, my fault, but thanks for weeding through that and understanding what I meant.
1 - 3 of 3 Posts
