1 - 5 of 5 Posts
i have done everything apart from overclocking i think
i have no page file (i got 1024mb of ram i dont need)
^ that actually helped it alot!
i have upgraded my CPU from 2.66 to 3.06ghz celerons
i will be upgrading my motherboard soon.
i have alot of fan cooling
(my cpu is designed to run at arun 67C
and i keep it runing from between 52-65C
is there anything else that i can do to my computer to maximize speed and perfromance?
im out of idea and i want to see if i missed anyones nifty little tricks.
if you need my current system specs they are below
i have a graphics card coming so theres no need to say get one
radeon X700 coming ^-^
ill be monitoring this post for the next half hour or so so just drop me one if you have any ideas
THANKS!
~Rabies
You should have a page file. Get better processor cooling as 65C is way too hot. Try to keep it under 55C. Under 50 is optimal.
I remember when......
I looked at that turbine thing myself a few times.......but it is WAY heavy and way big.....the real benifit to it is that it sucks air laterally, so you don't have to worry about the fan opening being right up against your side panel on smaller cases........but you'd have to brace it with something I would think, it's like a boat anchor........
Are those temps your IDLE temps? Or load?
1 - 5 of 5 Posts
