1 - 5 of 5 Posts
Not new to Overclock.net
This is the top of the side panel. As you can see, I can't bend that part inward or else this will no longer go back on the case, so I need to put something on these parts between those parts that snap into the case. But what can I put on it? I'm vaguely remembering strips of a soft rubbery material that go onto thin edges like this, but I don't know how to find them.
Rig Advisor
This is the only thing that comes to mind, I have about 50 FT of it.
I used some trim from the auto parts store similar to what Avacado linked when I cut the hole for my EK pump/res combo.
2487213
Oh, of course, it's called "trim". lol Thank you.
Iconoclast
I'd probably just use masking or gaffer tape, but I'm a cheapskate.
1 - 5 of 5 Posts
