is there such a thing?
590 Views 12 Replies 7 Participants Last post by  CattleRustler
an extension cord that plugs into a standard US 3 prong outlet, that is 25' long, and is rated for 20 Amps or better.
I cant for the life of me find one!
the outlet circuit is on a 20 amp breaker so I know its 20 amps
halp!
local retailers preferred, not online purchase
1 - 13 of 13 Posts
Check drying machine or electric oven hook ups?
EDIT: never mind they had 2 specs listed, I read the wrong one, sorry
Dryers and ovens dont use a standard 3-prong connection.
I looked on www.mcmaster.com and they don't even have what you need... For 20A, you're looking at 12AWG wires and I don't think the standard outlet is rated for that much.
It's called an extension cord. Home depot, lowes or any other store of that nature will carry them. Look for 12 gauge wire, which is rated for 20 amps.
EDIT: And are you doing a full 20 amp load? What are you running on this. 12AWG extension cords are really bulky.
Heah, CR.
I know that you wanted a local source, but if you fail to find what you need in NYC then perhaps This is what you need?
Also, I had a similar dilemma with my primary UPS. Iirc I found what I needed at Friedman Brothers (comparable to Home Depot).
Good luck you Modding Madman. You rock!
Not all 12 gauge cables are rated for 20 amps, it will depend on the length of the wire, for 25 feet 12 gauge should work, anything longer than 25 feet wont support 20 amps though.
Don't most/all 20 amp cords have the power and neutral prongs set up horizontal/vertical? I know with 15 amp cords they're both vertical, but I'm pretty sure the 20 amp cords are designed so that they wont fit in a 15 amp receptacle.
Example 15 amp vs 20 amp receptacle:
thanks for the replies guys.
its to run a MIG/GMAW-FCAW welding machine that is rated for 60hz Single Phase 20 Amp off of a standard 110-120V recepticle as pictured by HeadCase9 above, on the left. The plu on the unit is the standard shape, not notched. Its a washer/dryer circuit in my basement, inside from the garage. Its the only 20 amp circuit I have down there. Turns out I have been using a 15 amp extension cord all this time with my less beefy stick welder (also 20 amp input but 90 amps dc out) and dint know it. I have had that thing pinned to max output but I never cooked the extension - which puzzles me. It might be because its short runs like 15 seconds tops. I dont have a multimeter that can measure amperage above 10A so I cant test it, but the voltage at the recp is 123.3.
My new MIG welder can deliver 140A DC when set on full (E/A-E) but I havent gone past D/A-E setting yet (luckily). I needs me a new cord or there is some funny business going on with the recepticle. I know the standard plugs can plug into the notched 20 amp recepticles. Maybe the receptical needs to be changed to notched and get a notched cord?
what Syrillian linked to is EXACTLY what I need
that, and a new multimeter
You can just buy the plugs and service cord from mcmaster and make your own. That's typically what I do.
I need locally tomr
I think its just home deepblow's web site search is horrid. I bet you they have them.
I have to go there tomr to get some angle iron and bar because I am making a cart for my new mig machine
its gonna have upright handles to move it and store the gun and ground clamp, and an area in the back to house a gas bottle for when I add gas in the spring (MIG/GMAW) I am currently doing MIG/FCAW
turns out when I search hd's site by 12/3 instead of 20 amp extension cord, they do stock 25' 50' and 100' lengths. Ill pick up a Rigid 25' 12/3 cord today. If the 15 amp 14/3 that I have been using didnt blow up, the 12/3 certainly wont, regardless if its rated for 15 or 20 amps on the sticker
1 - 13 of 13 Posts
