Is this 3D Mark 06 Score OK ?
1048 Views 11 Replies 7 Participants Last post by  Darkslayer7
Hi guys . I runed my firt 3D mark benchmark , ad i got 13601 scores . Is this a good score ?
PS: ony the CPU is a bit OC ed ( from 2.6 to 2.86 GHZ ) , the GPU not .
Validation :
1 - 12 of 12 Posts
Not bad, give that 620 some more megahurtz and your score will go up quite a bit.
Run with default settings. I noticed you changed the resolution which gives you different results than everyone else so its harder to compare.
its about right yeah, but its a little on the low side from what I would expect from a 4870. overclock your cpu a little and that will boost it for sure
check out hwbot.org and compare it to other cards to get a good idea
It's not bad but I think it would be better in Win XP the 7 but not sure. I do 15866 with the same card but my CPU is OC'd so I think that where the difference is. OC you cpu and it will get better!!
Not bad but o'c that 4870!
Here's mine with my old 8800GT o'cd
Originally Posted by kow_ciller View Post
Change resolution back to default.
do this OP, I just noticed that your resolution was modified. change it to the default 1280x1024 setting and run it again. that could help as well
I made a new test with normal settings . Almost 14 K
cpu bottleneck for now, since scores didn't really change the CPU is lagging behind.
Definitely your CPU. I get just over 12K with only an 8800GT. The real question you should ask is "are my game framerates OK?" As long as you can play what you need to, I don't put much stock into benchmark scores.
Crysis DX 10 Max 1440x960 40-50 Fps . I wont oc my CPU , and my GPU for now , cuz i have a mid quality PSU . Next month i will buy a 850 W Chieftech CFT-850G-DF PSU , and an Artic Coller Freezer XTREME rev2.0 cpu cooler . And after that .... SOME OC'ing
1 - 12 of 12 Posts
