Is this a good enough set up for a q6600 GO?
276 Views 4 Replies 3 Participants Last post by  waqasr
Dtek v2 Cpu Block
Gtx 240 Radiator
2 Ultra kraze push 3000 rps fans
1/2 - 5/8 tubing
koolance Res http://www.koolance.com/water-coolin...product_id=651
some BP fittings
is this a good set up to cool a q6600 quad?
1 - 5 of 5 Posts
there probably going to say get this one http://jab-tech.com/Swiftech-Apogee-...k-pr-4246.html
then it should be ok
if you can get this then http://jab-tech.com/D-tek-Fuzion-V2-...t-pr-4154.html
Thats fine for the Q6600...try to keep it just a cpu loop though...also what pump are you getting?
1 - 5 of 5 Posts
