is this a good memory?
619 Views 13 Replies 4 Participants Last post by  und0
what do you guys think of this http://www.ncix.com/products/index.p...L&promoid=1033? i'll be overclocking later on so i'd like to know if this memory is good enough. note that i have 955BE with msi 790fx-gd70 mobo... thx in advance
1 - 14 of 14 Posts
You don't need triple channel memory.
but anyways, that ram is a little loose tbh. Try to find one with better timings.
can you show me one please.? post link and i'll look it up..
thx
It's a toss up between the Mushkin Enhanced and the G.Skill Ripjaws.
http://www.newegg.ca/Product/Product...82E16820146871
http://www.newegg.ca/Product/Product...82E16820231279
The ripjaws do run at a lower voltage than the Mushkin so keep that in mind.
so you're saying lower voltage is better? sorry im new to this
It depends on your board, I'm unsure of what the normal voltage range of that board is.
Currently what is your RAM VTT set to?
hehe i haven't put my rig together yet..
im just ordering the parts right now. actually this is the last part that i need b4 i start building. sorry for the trouble
can u still help me?
my vote goes to mushkin - heard lots of good stuff about them but have yet to try anything made by them.
What mobo you have will dictate what voltages you need. You'll only know 100% what the voltage is by testing it with a volt meter. No software or BIOS setting is ever exactly correct. I set my RAM at 1.67 to reach the desired 1.65 operating voltage. It all depends on the RAM's requirements and the capabilities of your mobo. Usually 1.65 is pushing it though.
Go for the Mushkin, if at all try to find these.
http://www.newegg.ca/Product/Product...-777-_-Product
Mushkin Enhanced Black - 996601
Stay away from 996625 - they have issues with that board.
I think the 996657 will do 6-6-6-18 @ 1333MHz
Main difference between AMD and Intel when it comes to memory is that with Intel, high frequency matters upto 9-9-9-30, with AMD keeping moderate frequencies and tight timings 7-7-7-20 gives better performance
Get these ripjaws, @ $80, they'll be great
http://www.newegg.ca/Product/Product...82E16820231303
o_O that's a very good deal...
any1 else agree?
thx for the help peeps! <3 +REP
1 - 14 of 14 Posts
