is this a good oc 260gts
593 Views 3 Replies 4 Participants Last post by  Shroud
is this a good oc or should i go higher load temp is 68c
1 - 4 of 4 Posts
Yea that's a good overclock, shader may be able to go higher?
Its not a horrible OC by any means, you can definitely take the shader a little higher if you want to squeeze some more out of it.
1 - 4 of 4 Posts
