1 - 6 of 6 Posts
Hi, I just got another 8800GT for SLI. I was getting the dreaded nvlddmkm error until I replaced my ram. Now I am getting this in crysis. http://i37.tinypic.com/a2bzfn.jpg
I also get a crash to desktop every 30min or so with stalker clear sky (patch 1.5.04). This may just be a bug, it would not be the first one in that game
I tried patching up, but my savegames did not work. My main concern is Crysis. Could this be a GPU problem, or just an odd bug. If I alt +tab out of the game then back in, it goes away for a while. It is not always as servere as in the picture. It is playable, but very annoying. Also, the humvees don't have any wheels, they just float around (this part is kinda funny
) Any ideas on how to fix? I am patched to 1.21
Well, I have not OCd any. Both of these cards are the XFX XXX edition (core clock of 670). I also have duorbs on them and they do not go over 55C.
make sure you have the latest drivers installed
i had that same problem and it was the drivers
you have to uninstall it completly and install the most recently driver from scratch
im sure it will work
PS: check your sli cable is mounted props as well
Reactions: ChIck3n
Discussion Starter · #6 ·
Originally Posted by DK_mz
...check your sli cable is mounted props as well
Ok, thanks for that. I have been removing my GPUs testing another problem I was having (bad RAM). I have been checking them, but I looked again after you said this. I looked at my GPUs, stopped, looked again, turned around, and there sat my SLI bridge... Right where I had left it the last time I removed my GPUs.....
X10^
REP+ for me being dumb
That seemed to fix the problem.
1 - 6 of 6 Posts
