So i was in newegg and i was fooling around with some combos and stuff and here is what i got.
ASRock M3A780GXH/128M AM3 AMD 780G HDMI ATX AMD Motherboard - Retail
Item #: N82E16813157161
Return Policy: Standard Return Policy
Protect Your Investment (expand for options13-157-161|hide options13-157-161)
Service Net Replacement Extended Warranty Plan
The product will be replaced and shipped directly to you at no charge(more info13-157-161.0.18)
* 1 year: $10.99
* 2 year: $16.99
$89.99
select item 2 quantity of item 2
XFX HD-487A-ZHFC Radeon HD 4870 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
Item #: N82E16814150394
$149.99
select item 3 quantity of item 3
CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 ... - Retail
Item #: N82E16817139005
Protect Your Investment (expand for options17-139-005|hide options17-139-005)
The product will be replaced and shipped directly to you at no charge(more info17-139-005.0.18)
* 1 year: $10.99
* 2 year: $16.99
-$60.00 Instant
$20.00 Mail-in Rebate Card17-139-005
$159.99
$99.99
select item 4 quantity of item 4
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Dual Channel Kit Desktop Memory Model F3-10600CL9D-4GBNT - Retail
Item #: N82E16820231253
Return Policy: Memory Standard Return Policy
$59.99
select item 5 quantity of item 5
Microsoft Windows Vista Home Premium SP1 64-bit for System Builders w/ Tech Guarantee - OEM
Item #: N82E16832116677
Return Policy: Software Return Policy
$109.99
select item 6 quantity of item 6
Scythe SCKTN-3000 92mm Sleeve "KATANA3" 3Heat Pipes CPU Cooler - Retail
Item #: N82E16835185096
Protect Your Investment (expand for options35-185-096|hide options35-185-096)
The product will be replaced and shipped directly to you at no charge(more info35-185-096.0.18)
* 1 year: $6.99
* 2 year: $11.99
$26.99
select item 7 quantity of item 7
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core Processor Model HDZ955FBGIBOX - Retail
COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower Computer Case - Retail
Item #: N82E16819103674
Return Policy: CPU Replacement Only Return Policy
Item #: N82E16811119137
The only diffrence between the two builds are the case and the gpu.
edit: also the cpu's are diffrent
* 1 year: $10.99
* 2 year: $16.99
$89.99
$149.99
* 1 year: $10.99
* 2 year: $16.99
-$60.00 Instant
$159.99
$99.99
$59.99
$109.99
* 1 year: $6.99
* 2 year: $11.99
$26.99
