1 - 6 of 6 Posts
Hey guys so I took apart my old wc system
an I will be using an old swiftec apagee gt block that I bought an. I7 plate for.
Will it ok to use with an i7?
I was getting good temps with my c2q q6600
please need input asap?
Also it's not as shiny for some reason anymore on the contact part,
what would b the best way to clean it up, what should I use liquid wise?
It won't work as good as the newer block, it should still be much better than air though. That said, if you can get your hands on an Apogee XT, Heatkiller 3.0, or an EK supreme HF, I advise you to do so.
"Shinyness" doesn't help the cooling performance, but clean it with some rubbing alcohol to make sure there isn't any gunk on it.
Ok thnx a lot man, so an in about a month I'll be able to get a new on, which one u think I should get?
U listed a couple but which one u think is best
If you want to restore the shine for aesthetic reasons.... coat it in ketchup for 5 mins. The vinegear will clean it up nice.
The block will work fine and should not affect temps by more than ?3C?
1 - 6 of 6 Posts
